Hi friends. Today i will show you how to DIY Digital Soldering Station Without Programming
Step 1: Watch the Video
In this video. I show you how to i make the digital soldering station. You can check the step below for more detail
Step 2: Make the PCB for Hakko Soldering Station
You can download all of thing need to make PCB here. You can make at home by yourself but you can use my gerber file and upload tohttps://jlcpcb.com/m for make PCB online. I order PCB from https://jlcpcb.com/m alot of time and i alway get PCB with high quality only 2$ for 10PCB and Big Discount on First order Shipping.I use Eagle software for make schematoc PCB and gerber file
Step 3: Make Digital Temperature Meter
I use IC ICL7107 for make Make Digital Temperature Meter. That is cheap IC you can use it without programming.The Schematic, PCB and gerber file you can download in the previous step. Use the Protues Software for open file.
Step 4: Finish and Get Good Soldering Station
I use the box from old laptop PSU. Look it is great for make Digital Soldering Station.Soldering Iron Handle for HAKKO 907 with sensor a1321 insite
youkito1991
rahmanshaber
selena1995
