Here are a couple of diagrams of the boot process.
- at reset, push first bootloader into external RAM then reset eZ80 to start first bootloader
- first bootloader loads second bootloader/disk manager/disk operations binary from microSD
- second bootloader mounts virtual disks for drives A and B, loads CP/M from reserved tracks of drive A, jump to BIOS coldboot entry point
- CP/M running, virtual disk access provided by BIOS and mixed-memory mode disk I/O function
The limited amount of flash in the Z8 drives the need for two bootloaders. The largest Flash for an 8-pin Z8 is 8KiB. The desire to keep the µP and µC Zilog drives the Z8 and the board size drives 8-pins.
