i have moved the feature of NEW_METHOD true to memCache.h folder, when it is set to true the code now uses 5k less of data here is how.
i have changed the eeprom data either method to get the data from flash memory. the old mem management still collects data into pixel matrix, of float, and int.
i removed the need for these variables so far. (i made code not use pointers, and i switched code that reads the array to a function that requests data from the cell. since data is in progmem it is almost as fast as a ram read.
float alpha[768];
int16_t offset[768]; //we dont need this anymore
ill show the old method of getting offset (but after i removed the struct and pointer
void ExtractOffsetParameters( )
int occRow[24];
int occColumn[32];
int p = 0;
int16_t offsetRef;
uint8_t occRowScale;
uint8_t occColumnScale;
uint8_t occRemScale;
occRemScale = (eeDataGetStoredInLocalEPROM(16) & 0x000F);
occColumnScale = (eeDataGetStoredInLocalEPROM(16) & 0x00F0) >> 4;
occRowScale = (eeDataGetStoredInLocalEPROM(16) & 0x0F00) >> 8;
offsetRef = eeDataGetStoredInLocalEPROM(17);
if (offsetRef > 32767)
offsetRef = offsetRef - 65536;
for(int i = 0; i < 6; i++)
p = i * 4;
occRow[p + 0] = (eeDataGetStoredInLocalEPROM(18 +i) & 0x000F);
occRow[p + 1] = (eeDataGetStoredInLocalEPROM(18 +i) & 0x00F0) >> 4;
occRow[p + 2] = (eeDataGetStoredInLocalEPROM(18 +i) & 0x0F00) >> 8;
occRow[p + 3] = (eeDataGetStoredInLocalEPROM(18 +i) & 0xF000) >> 12;
for(int i = 0; i < 24; i++)
if (occRow[i] > 7)
occRow[i] = occRow[i] - 16;
for(int i = 0; i < 8; i++)
p = i * 4;
occColumn[p + 0] = (eeDataGetStoredInLocalEPROM(24 +i) & 0x000F);
occColumn[p + 1] = (eeDataGetStoredInLocalEPROM(24 +i)& 0x00F0) >> 4;
occColumn[p + 2] = (eeDataGetStoredInLocalEPROM(24 +i) & 0x0F00) >> 8;
occColumn[p + 3] = (eeDataGetStoredInLocalEPROM(24 +i) & 0xF000) >> 12;
for(int i = 0; i < 32; i ++)
if (occColumn[i] > 7)
occColumn[i] = occColumn[i] - 16;
for(int j = 0; j < 32; j ++)
p = 32 * i +j;
offset[p] = (eeDataGetStoredInLocalEPROM(64 +p) & 0xFC00) >> 10;
if (offset[p] > 31)
offset[p] = offset[p] - 64;
offset[p] = offset[p]*(1 << occRemScale);
offset[p] = (offsetRef + (occRow[i] << occRowScale) + (occColumn[j] << occColumnScale) + offset[p]);
new method
int16_t ExtractOffsetParametersRawPerPixel(uint16_t value )
{//we get row and collumb data and process from there
uint8_t col= (value&31) ;//we take bottom 5 bits and add as we use 1-32
uint8_t row=(value&65504)>>5;;//this should have upper bits only
//int occRow[24];
//int occColumn[32];
//we only need to store one word each as conversion done on the fly
int occRow;
int occColumn;
uint8_t p = 0;
int16_t offsetRef;
offsetRef = eeDataGetStoredInLocalEPROM(17);//11hex
//we have raw number for offset now
p=row&3;//we have 0-3 for data bits
uint8_t i=row>>2;
if (p==0) { occRow = (eeDataGetStoredInLocalEPROM(18 +i) & 0x000F);}
if (p==1) { occRow = (eeDataGetStoredInLocalEPROM(18 +i) & 0x00F0) >> 4;}
if (p==2) { occRow = (eeDataGetStoredInLocalEPROM(18 +i) & 0x0F00) >> 8;}
if (p==3) { occRow = (eeDataGetStoredInLocalEPROM(18 +i) & 0xF000) >> 12;}
if (occRow > 7)
occRow = occRow - 16;
p=col&3;//we have 0-3 for data bits
i=col>>2;
if (p==0) { occColumn = (eeDataGetStoredInLocalEPROM(24 +i) & 0x000F);}
if (p==1) { occColumn = (eeDataGetStoredInLocalEPROM(24 +i)& 0x00F0) >> 4;}
if (p==2) { occColumn = (eeDataGetStoredInLocalEPROM(24 +i) & 0x0F00) >> 8;}
if (p==3) { occColumn = (eeDataGetStoredInLocalEPROM(24 +i) & 0xF000) >> 12;}
if (occColumn > 7)
occColumn = occColumn- 16;
// for(int i = 0; i < 24; i++)
// for(int j = 0; j < 32; j ++)
// p = 32 * i +j;//this can be directly value
;//we have direct cell number
// offset[p] = (eeDataGetStoredInLocalEPROM(64 +p) & 0xFC00) >> 10;
int16_t temp=(eeDataGetStoredInLocalEPROM(64 +value) & 0xFC00) >> 10;
if (temp > 31)
temp = temp- 64;
temp =temp*(1 << occRemScale);
temp = (offsetRef + (occRow << occRowScale) + (occColumn << occColumnScale) + temp);
return temp;
the difference is now rather than pointing to a storeage in an array, i'm running a function that extracts the data from progmem.
