I have been doing further product research to see how this UV curing lamp could become more portable and work with easy to find off-the-shelf components that require minimal tools or easy-to-execute fabrication.
Pricing for 24"x24" flexible, portable UV curing lamp
- Bubble foil backing - $10.50 (this is enough for multiple UV curing ovens and reflecting surfaces)
- UV LED Strip - $13.00
- 12V 5A power supply - $12.00
- PCB - $1
- Foam core boards/light barrier $6 (optional - even cardboard could work!)
- Binder clips or A-clamps - $3
Total - $45.50
Portability
Optional portable battery pack to make this resin oven more field-ready brings the cost to ~$80
The portable battery pack linked above is ready to be paired with the flexible UV lamp design right out of the box. The battery pack is listed at supporting a 6000maH charge - which would equal 72wH. Since this UV lamp uses 24W, you could get 3 hours of UV exposures with this particular battery pack.
audreyobscura
