Attaching Stepper Motor and Mirror
A project log for Radial LED Projection ISS Tracker
A demonstration of an efficient way to use a fairly small number of addressable LEDs to convey polar coordinate information
bornachbornach 09/29/2018 at 18:450 Comments
I had initially tried a more complicated motor mounting method in order to accommodate the length of the wooden shaft, but then opted to glue the stepper motor directly to the cardboard disc, and instead just trim the wooden shaft down. Had I committed to doing this from the start, I would have trimmed the shaft down first before attaching the mirror to it.
Drilling a small hole into a wooden shaft would have been much easier to do if it didn't have a breakable mirror glued to it.
Rich text editor
