On The Art of Puppeteering
A project log for KARAOKEBOT
A 3D-Printed, Animatronic, Karaoke-Singing Robot
hunter-irvingHunter Irving • 10/05/2018 at 19:57•0 Comments
There are a few things one must take into consideration when building an animatronic karaoke-singing robot.
Perhaps the most important consideration is that of timing.
if your 'bot has sloppy animations, it'll look less lifelike and the illusion will be lost.
Since I was using a Digital Audio Workstation (DAW) to program speech, I thought I might as well use it to program animations as well. A separate, soundless MIDI channel was created for animation, and I was able to slide "hits" (captured as MIDI NOTE_ON messages) and "releases" (captured as MIDI NOTE_OFF messages) around in real time to create believable facial animations.
A few tips for anyone looking to create a MIDI controlled robot:
Happy Hacking!
- Hunter
