150 led strip with wireless controller
configuration.yaml:
light: # LEW WS2812b - platform: mqtt name: "Pablo's SmartLight" retain: false state_topic: "stat/psl/POWER" command_topic: "cmnd/psl/POWER" availability_topic: "tele/psl/LWT" qos: 1 payload_on: "ON" payload_off: "OFF" payload_available: "Online" payload_not_available: "Offline" optimistic: false brightness_state_topic: "stat/psl/Dimmer" brightness_command_topic: "cmnd/psl/Dimmer" brightness_value_template: "{{ value_json.Dimmer }}" brightness_scale: 100 rgb_state_topic: "stat/psl/Color" rgb_command_topic: "cmnd/psl/Color2" rgb_command_mode: hex rgb_command_template: "{{ '%02x%02x%02x' | format(red, green, blue)}}" effect_state_topic: "stat/psl/Scheme" effect_command_topic: "cmnd/psl/Scheme" effect_value_template: "{{ value_json.Scheme }}" effect_list: - 0 - 2 - 8 - 9 - 11 - 12
Effect list from Tasmota Schemes: https://github.com/arendst/Sonoff-Tasmota/wiki/Commands
