So, I got distracted on this project and decided to just buy some pre-made modules so I could make music.
In the process of doing that, I discovered that the original housing only fit my modules (the standard clearance around the mounting holes wasn't enough). So I redesigned it to use pre-made Eurorack rails and lasercut panels.
The updated lasercuttable design is designed in OpenSCAD, is parametric, and available on this project's Github repo.
