A diversion
A project log for Modular Synthesizer
An attempt to learn basic analog electronics by designing and building a modular synthesizer from the ground up.
steve-pomeroySteve Pomeroy • 07/08/2020 at 12:38•0 Comments
So, I got distracted on this project and decided to just buy some pre-made modules so I could make music.
In the process of doing that, I discovered that the original housing only fit my modules (the standard clearance around the mounting holes wasn't enough). So I redesigned it to use pre-made Eurorack rails and lasercut panels.
The updated lasercuttable design is designed in OpenSCAD, is parametric, and available on this project's Github repo.
