Soldered everything down and everything is functionally perfect.
Only minor issue is I forgot to remove "i2C Pullups" from the board silkscreen but other than that, the boards are good to go.
I actually still have 4 spare since the first one worked perfectly. Let me know if you'd like one!
I also reduced the delay from 17 to 10 as I getting a few typos (could be just because it's 3am). Still, 9/10 = 90% sleep is not bad!
