![](https://cdn.hackaday.io/images/4210511547747169345.jpg)
A bit of whacking with a large hammer and some small spanners and the gimbal starts to take shape. The laser device has been tested and successfully burnt a hole in my carpet at distance = 1 metre.
A project log for Ai Equiped Wasp (and Asian Hornet) Sentry Gun
A powerful laser guided by cameras will vaporize these pests in flight. Hopefully.
Neat design!
Is the rotating platform stage heavy enough to cause wobble at all on the servos bearings?
there is a bit of wobble sometimes when the servo speed kicks in at resonant frequency so a bit of damping might be a good idea, but it's not too much of a problem :)
