After hour of design and 3D printing, here are the start of this project!
![](https://cdn.hackaday.io/images/5431801538680238798.jpg)
The neck of the Ukulele can be print in one piece in a tall 3d printer as a CR10 and design to fit as a gameboy cartridge perfectly without any glue or screw.
This print will need a little tuning to be fully OK but for a trial i will work
![](https://cdn.hackaday.io/images/4133761538680438672.jpg)
![](https://cdn.hackaday.io/images/6909201538680456734.jpg)
With a diapason of 350mm this is a soprano which fit perfectly for travel!
To reinforce the body, a thick cardboard is lasercut to replace the original PCB
![](https://cdn.hackaday.io/images/8569251538681074263.jpg)
![](https://cdn.hackaday.io/images/7820011538681313401.jpg)
The bridge will be out the printer tomorrow to the first build an try!
![](https://cdn.hackaday.io/images/2430401538682021166.jpg)
