I must admit I'm not experienced woodworker, so I asked my colleague to help me out a bit. We drew a shape of cello body on paper, cut out and used as form to be retraced on 6mm thick plywood.
![](https://cdn.hackaday.io/images/3281231538778685375.jpg)
This was cut twice, for both faces of instrument body.
![](https://cdn.hackaday.io/images/3317451538778758426.jpg)
Backside has I-shaped cutout, to insert electric parts later.
![](https://cdn.hackaday.io/images/226721538778847030.jpg)
Metal spacers are to keep the halves together. Notice the wire stamped to inner faces - this was planned to keep polycarbonate shell forming side walls in place; unfortunately the polycarbonate was difficult to bend into desired shape, so we scrapped the idea, leaving only front and backside of the instrument.
![](https://cdn.hackaday.io/images/8653621538779077055.jpg)
Backside cutout back at place.
Fingerboard was made of single 50x6x1cm wood block, with 3D printed parts holding it in place
![](https://cdn.hackaday.io/images/3169991538779470034.jpg)
Here is picture of complete body, with cutout for speaker and sensor head installed in place
![](https://cdn.hackaday.io/images/466101538779567949.jpg)
