Jason is continuing to refine our fillet application technique and mold production;
The upcoming set is name Module Set 5, it contains two straight sections, two specialty elements (in development) and 19 derived units.
It will be a little while before we do a public release since we want to get naming conventions and organization squared away so there are no missing elements for people to start fully utilizing this system.
Deciding on the formatting template for communicating a design will be a work in progress (essentially, we need to decide on an excel sheet layout.)
We are going to start printing modules A and B with an end adapter for materials testing. I changed the wall thickness to 2mm for the print so that it is compatible with the rest of module set 5.
We are getting in touch with Brian, to work on materials processing this week.
David Troetschel
