We generated a module set, but incorrectly made the arm thickness two inches rather than one.
We just had to change the grasshopper script and then regenerate the modules using the endpoint table.
This gives us our one inch output using the grasshopper script.
Since we are really only using modules A-K right now this is going pretty quickly. We are hoping to go into Mindesk soon to test these modules.
David Troetschel
