Like the SAA5246, but with internal 8K DRAM.
DIP48 pinout is very similar, the pins that were external SRAM signals on the SAA5246 are to be left unconnected on the SAA5281. There are a few exceptions - pins:
6 is REF+, which should go to a 100n capacitor
21 output can also be DV
36 input CLK EN
37 output CLK OUT
44 output LINE23
Internal RAM can't be dual-ported to an external processor for fast video, or paging a larger-than-8K SRAM, but it avoids the chore of wiring it to an external RAM. This project is primarily to provide a useful video over the I2C bus, so I shall be using this chip.
Cost is reasonable, I found a source that had over 130 devices for about £4.28 each.
The wiring is fairly simple (NB pin numbers for DIP52, not DIP48):
