25 Oct 2018
Proceed with the design
![](https://cdn.hackaday.io/images/8319911541521241092.jpg)
- capsule machine use a "present box" concept for the design outcome
-Getting Message from others its like a surprise
FLOWCHART
![](https://cdn.hackaday.io/images/622901541521418579.jpg)
- User have to read thru the instruction shown in-front of the machine to understand how to use it.
- After they read the instruction they are require to press the button at the end of the instruction
- Upon user press the button, a compartment at right-side below of the box will open by a servo, and there is an empty ball inside for user to take it out. There will be a green light LED shines on the ball, until user take the ball out the LED will become red.
- User will take the ball write and message to place in the ball. Then user need to toss it into the machine
- Once the ball has being toss into the machine, a servo will unlock the latch for user to spin the notch.
- In return user get a ball that has written message by other people.
- As instruction stated user need to return the empty ball back to the compartment.
- Once the compartment micro-switch detect the ball has being placed back the LED will return green again.
- And the servo will lock the compartment door.
MECHANICS
![](https://cdn.hackaday.io/images/5343951541522353548.jpg)
![](https://cdn.hackaday.io/images/4887441541522353541.jpg)
![](https://cdn.hackaday.io/images/6695781541522353511.jpg)
Measurement
![](https://cdn.hackaday.io/images/3620931541522471496.jpg)
![](https://cdn.hackaday.io/images/2515511541522471681.jpg)
![](https://cdn.hackaday.io/images/9075211541522471698.jpg)
![](https://cdn.hackaday.io/images/8394821541522471741.jpg)
![](https://cdn.hackaday.io/images/6707371541522471774.jpg)
