11 Oct 2018
Mechanics Reference
Video reference for capsule machine
- https://www.youtube.com/watch?v=tCOuWPpyK8ghttps://www.youtube.com/watch?v=tCOuWPpyK8g
- https://www.youtube.com/watch?v=LzXOh-4qAlE
- https://www.youtube.com/watch?v=tWORdDFjrm4
- https://www.youtube.com/watch?v=HnHLguMtf4Y
Mechanics Sketch
![](https://cdn.hackaday.io/images/6592631539251893224.jpg)
- Write a message and toss into the capsule machine
- (A) sensor detect if people toss the ball in, if yes the latch we open for the ball to enter the machine.
- At the same time the notch will be unlock, for use to spin
- (B) while spinning the notch the "ball holder" will lead the ball downwards to the collect area
How do the notch works
![](https://cdn.hackaday.io/images/8724021539252296327.jpg)
- There will be 2 latch blocking the notch from spinning
- Once the sensor is checked, another motor above the latch will pull it up
- and now user will be able to twist the notch.
Reference
- As reference common coin operated capsule machine, use coin to push up the latch
- In our case we use a motor to pull up the latch.
