All I have some far are some sketches of the design I will use for this telescope project. However, before buying any parts, I will test out the dish with my SDR and some LNAs - to see if I can receive a signal at 1420MHz.
I also have an alternative design. I don't like this one as much, since it will probably be more difficult to build, and wouldn't necessarily provide better results. Here it is:
Gonçalo Nespral
