Bioelectronic Measurements on android
Capture biologic parameters on the cheap, using arduino a and open source electronics
Public Chat
Measure, temperature, gsmr, pulse, blood preasure etc, using arduino an web technology on the cheap usin arduino
HI
I will beging adding temperature measumerent using lm35, arduino and android programing on appinventor,  like first item, more in a close future, feel free for comment and suggesting ideas and corrections, "English is not my native language, so you can expect some mistakes.
  • First
    divertidoxxx10/07/2018 at 22:41 0 comments
    This is the first step on creating and arduino project for bioelectronic,  every  weekend i will update all
View project log
  • 1
    Circuit for Temperature using Lm35
  • 2
    Arduino code for lm35
    // Script para leer temperatura utilizando un LM35
    // Declaracion de variables
    float tempC;
    int tempPin = 0;             // Definimos la entrada en pin A0
    void setup()
    // Abre puerto serial y lo configura a 9600 bps Serial.begin(9600);
    void loop()
    // Lee el valor desde el sensor
    tempC = analogRead(tempPin);
    // Convierte el valor a temperatura
    tempC = (5.0 * tempC * 100.0)/1024.0;
    // Envia el dato al puerto serial
    Serial.print(tempC);
    //Serial.print("
    grados Celsius\n");
    // Espera cinco segundo para repetir el loop
    delay(5000);
  • 3
    Circuit for pulse
View all 4 instructions
