We couldn't manage to rush out the project's submission due to the capability of the 3D printer and the malfunction of our code.
We have struggled on the code and the lights due to the voltage of our LED lights are too high and it caused the LED light burnt. We have make quite a lot of unexpected mistake because we lack of experience on doing installation.
Working on the base after we get some feedback on the user test which some of the user have commented that the base are not stable enough to hold the project.
We had used two kind of wood to work on the base but had struggle on the choices of the wood's thickness which is between 3mm and 6mm. We have decided to use the 6mm wood because it's more thick and have a better stability compared to the 3mm's.
We used Live Hinger for the base pattern to make it curve-able and more stable, but we had also struggled on spending quite an amount on the wood and keep refining on it.
We get around 10 person to do Beta Test for our project, including lecturers and students.Introducing our project to them and we actually received a lot of feed back to help us improve our project.
We supposed to be done 80% - 90% , but we only managed to done 1/8 due to all the mistakes and technical problem that we are facing. 1. What do you think of the design of our project?
It is quite unstable and quite
fragile.
The looks of it is fine but it
should be more solid.
Looks quite cool with lights
effects on.
It looks quite interesting but looks too soft.
It look fragile.
2. At the first glance do you know how to interact with it?
Not really I thought that i can touch the words part too.
Don’t know, maybe a instructions would be good.
It didn’t really attract me to touch it at first.
If there are some striking lights i might go and touch it.
I know it’s interact by touching it after you told me.
3. What do you think of the concept? (Crossword puzzle)
Nowadays young people don’t really play crossword puzzle right?
I quite like the concept, it’s fresh for me.
Cool wei the idea of this.
The idea itself is fine but why in this shape?
This idea I think work quite well actually.
4. Does this convey the message of United is Power?
I think it can work after you explain the idea to me.
Oh it’s about Unity? Didn’t know that.
If this have a rational then it would be clear.
5. How can we improve our project?
Make your project more solid, now it’s too soft.
Maybe give it a instructions for users.
Why don’t you make it spin? So it looks more cool. x3
Rational is very important for this project.
**Some improvements that we gonna change.**
- Stick in all the missing parts, and make it more solid.
More Prototyping ,improving the mechanism and interacting part.
Realised that the materials is not transparent enough to let the lights actually shine through. And also the 3d printing will takes up a lot of time during the whole project.
Decided to use tinted acrylic board instead of full black acrylic board to cover the front part of the installation.
Did some attempts of the measurement of different parts to make sure it fit.
Testing with the structure of the installation to see is it workable.
Came out with ideas called "Glare the night" and "Tune Memoir"
For Tune Memoir we improved the inner idea and try to implement our insight into our idea.
And for Glare The Night we thought of a idea about representing people as a piece of important piece of Kuala Lumpur, and try to combine our insights to our idea as well.
