Watson is a relatively simple RF power meter based on the "120 dB Measurement System" outlined in the Analog Devices (AD) AD8307 data sheet. Watson uses a AD603 X-AMP for automatic gain control to extend the AD8307 dynamic range from 80dB to 120dB! Watson has a narrow and fixed measurement band centered on 10.7 MHz and was developed as the detector for a low cost spectrum analyzer design. The layout was done using KiCAD on an Arch Linux dedicated laptop.
I'm curious about measuring RF radiation and its effects on mental clarity/sleep/health etc. I'm not so knowledgable about RF, was the choice to display logarithmic conformance an application specific choice or is that how you measure RF?
Are gerbers available?
73 VK5ZIF
