I should be posting an initial version 1.0 of the code this week, as well as production hex/binaries for easy flashing. The code is pretty good now, will have plenty to improve/work on as this moves forward, but it's at a nice spot now.
I will work on updating the build instructions this week, to include pics/mods to the oven case, as well as installing the LCD itself.
Also will put up a 'flashing instruction' doc, step by step on how to flash the board with the FTDI cable, using a production .bin/.hex file...
Should have some goodies posted up this week..
The 7.0" screen looks SO good on this oven, only bad part is the one I received may be bad, as I get ZERO picture on it, the lcd backlight works fine. So I have to see if Newhaven can get me another, or if there is something else I'm missing..
But wow does it make a much better look than the 5.0" as to how it fits...
