Alright, got the WiFi module added into the design, wired one up to my current board, and got it working, using a free GPIO pin to control the enable of the module, so we can have a checkbox in the settings GUI to enable/disable the entire module.
Pretty sweet being able to do wifi and/or bluetooth, using a $3.80 part.
https://www.digikey.com/product-detail/en/espressif-systems/ESP32-WROOM-32D/1904-1023-1-ND/9381732
First thing I'm going to get working for this, is to have the wifi settings page working with the module, so you can set your personal wifi settings, so the module can talk to your access point.. also allowing custom settings of IP or use DHCP.
