After buying the Acton Blink Qu4tro, which still is one of the most powerful electric skateboards commercially available, I quickly realized my mistake. I assumed that a relatively small company located in Silicon Valley has enough influence on Chinese motor controller manufacturers to push their own demands through and make a good remote in the process.
My Qu4tro remote control was of such horrible quality that I decided a change is required to actually enjoy this fantastic piece of leisure equipment - which was otherwise almost impossible:
- At cruising speeds, the skateboard would show torque wobble and not run at constant velocity at all
- The remote has trouble communicating when in line of transmission of a wireless communication tower
- The remote has terrible mechanical properties, was way too light, felt very cheap and the throttle potentiometer was even pressure sensitive and would accelerate the board when pressed down - not good in stressful situations!
- The remote had a terrible battery indicator that only blinks in different colors at the bottom - the part that is literally hidden in the palm of your hand!
- The battery indicator for an EMPTY REMOTE was also just the same blinking LED in three green successive short blinks! (instead of the long green blinks when the board itself is fully charged!!)
- There are other major issues, that I will mention below when I go into detail about the communication protocol used
In my arrogance and wild feverish dreams I loudly announced my goal to completely reverse engineer this skateboard and take over control of the various bits and pieces. Something I thought I could probably do but had never really done before in great detail on a complex system like this.
About five weeks after my public announcement, I had enough and took the remote and board apart to look at everything, take a ton of pictures and start with searching for chip datasheets. With only two hits, I was pretty disappointed to realize, I'll not be able to take over these Chinese micro processors that are produced by the thousands and have absolutely no description at all!
However, I had two very dominant hits, that made this process possible:
- The wireless communication chip NRF24L01+ used in both, the remote as wel as the receiving end on the board
- The wireless bluetooth chip used for communication with the smartphone app
Apart from learning a lot during this process, I managed to reverse engineer the entire wireless communication protocol, write code around it to handle pairing and general communication, design my own custom electronics, enclosure and throttle mechanism and bring it all together using my PCB mill as well as my 3D printer.
This logbook is an aftermath of the steps I took and the success and fun I had doing this project.
The project documentation is work in progress even though version 1 of this remote works very well and already has 200 miles on its back without a single failure or disconnect.
The STL files can be found on my Thingiverse project page: https://www.thingiverse.com/thing:3273537
The code can be found in my GitHub repository: https://github.com/McNugget6750/Open-esk8-Remote
Hi could you please release the code for the remote somewhere, I tried what you uploaded to the github page but I can't seem to get it to compile due to missing files/directories. Any help would be appreciated.
