I have uploaded V0.2 of the schematic. Here is everything that has changed from V0.1.
- Added ESD diodes on USB C CC nets.
- Added single use fuse on VBUS. I wanted to use a re-settable fuse, but finding one that works up to 20V 5A that is small and cheap is tough. So I went with a one time fuse.
- Added balancing circuity.
- Switched to a slightly larger version of the STM32 to support all the IO needed. I initially underestimated the amount of GPIO's needed for the project.
- Added voltage divider networks for the ADC inputs to the STM32 for reading individual cell voltages.
- Added RGB LED for debugging and user feedback.
- Added UART from the STM32 for debugging. I may still add a UART to USB bridge for programming through the USB C port.
- Added 3.3V linear regulator. Needed to support up to 20V from Vbus and be a low drop out when VBUS is 5V.
- Added circuit to automatically steer the output of the adjustable regulator depending on what type of battery is connected (1s-4s).
I still need to add the supporting components around the adjustable regulator.
