I have the FreeRTOS Command Line Interface up and running on the STM32G0 over the UART
I plan on the stats command showing the entire state of the system. As well as an interface to modify the charging parameters on the fly.
I only have the scaling done for the Battery and Cell One ADCs.
Here is the current state of the CLI.
Starting LiPow. Type Help to view a list of registered commands. >help help: Lists all the registered commands stats: Displays a table showing the system stats [Press ENTER to execute the previous command again] >stats Variable Value ************************************************ Battery Voltage (V) 15.310484 Cell One Voltage (V) 3.795976 Cell Two Voltage (V) 0.000000 Cell Three Voltage (V) 0.000000 Cell Four Voltage (V) 0.000000 MCU Temperature (C) 0.000000 [Press ENTER to execute the previous command again] >
Alex Klimaj
