Command Line Interface Up and Running
A project log for LiPow - The USB C LiPo Battery Charger
USB Power Delivery Based Lithium Polymer Battery Charger
alex-klimajAlex Klimaj 02/02/2019 at 02:080 Comments
I have the FreeRTOS Command Line Interface up and running on the STM32G0 over the UART
I plan on the stats command showing the entire state of the system. As well as an interface to modify the charging parameters on the fly.
I only have the scaling done for the Battery and Cell One ADCs.
Here is the current state of the CLI.
Starting LiPow.
Type Help to view a list of registered commands.
>help
help:
 Lists all the registered commands
stats:
 Displays a table showing the system stats
[Press ENTER to execute the previous command again]
>stats
Variable                Value
Battery Voltage (V)     15.310484
Cell One Voltage (V)    3.795976
Cell Two Voltage (V)    0.000000
Cell Three Voltage (V)  0.000000
Cell Four Voltage (V)   0.000000
MCU Temperature (C)     0.000000
Rich text editor
