I finally got some time to work on this project again. Picked up where I left off and got 2s and 3s charging tested. It is now automatically charging and balancing 2s, 3s, and 4s batteries!
I set my bench supply to 20V and was able to get it to charge a 4s battery at 45W! It was also balancing and the temperature of the MCU did rise to 44C at room temperature. So heat may be an issue in the future.
Alex Klimaj
