8051 Alarm Clock
Based on a 8052 we designed an alarm clock in the most similar way to the basic commercial clocks.
Alarm clock specifications:
1. The clock must be exact.
2. The system must show the time (actual or alarm time) in the HH: MM: SS format in 7 segment displays.
3. The system must be able to be on time.
4. The system should show the time 12:00:00 after a reset. The alarm time will initialize it at 00:00:00
5. The system must have a switch to display the real time or the alarm time.
6. The system must have a switch (or two) to make the time (real or alarm) to be set up in time from the minute if a switch is used or the hours and minutes if They use two switches.
7. The system must always show the time (real or alarm), even when it is being updated.
8. The system should sound a buzzer for one minute if the alarm is activated.
THEORY
The main objective of this practice is that we start as a sudden, is that we are able to work with an 8952 microcontroller, that we are able to work with the assembly language and that we are able to combine everything we know about timers and interruptions.
The original idea of the practice was to finish in the first 12 hours of work, however, for reasons of understanding and hard work, as well as stress and lack of sleep was assigned another delivery date of this.
Among the fundamental parts of this practice was to make us work as a team, as well as to make us work under pressure, something that has not stopped doing for many errors that arise and problems that have to be solved.
DESIGN
The main objective of the practice is to make a digital clock where we can assign an alarm at the time we want and also buzzer so that this is the closest thing to an alarm clock.
To be as similar as possible to an alarm clock, we must use 7 segment displays, the numbers must be distributed in a way HH, MM, SS.
The circuit must have external interruptions, to change in the displays between the clock and the alarm, as well as to adjust alarm or time.
SCHEMATIC
repentina.txt
Alarm Clock Code in assembly language
plain - 7.92 kB - 10/15/2018 at 03:10
Download
  • 2 × Protoboard
  • 1 × AT89S52 Microprocessors, Microcontrollers, DSPs / Microcontrollers (MCUs)
  • 6 × 7 segment displays
  • 6 × Transistors
  • 6 × Resistors for power up of the display
View all 10 components
  • 1
    Assembly Code
    ROA EQU 7FH ;es Reloj o es Alarma
    USR EQU 50H ;Unidades de Segundos del Reloj
    DSR EQU 51H ;Decenas de Segundos del Reloj
    UMR EQU 52H ;Unidades de Minutos del  Reloj
    DMR EQU 53H ;Decenas de Minutos del  Reloj
    UHR EQU 54H ;Unidades de Horas del Reloj
    DHR EQU 55H ;Decenas de Horas del Reloj
    AIR EQU 56H ;Alarma es Igual al Reloj (0 <= AIR <= 4)
    ;Registros para guardar valores de alarma
    USA EQU 57H ;Unidades de Segundos del Alarma
    DSA EQU 58H ;Decenas de Segundos del Alarma
    UMA EQU 59H ;Unidades de Minutos del  Alarma
    DMA EQU 5AH ;Decenas de Minutos del  Alarma
    UHA EQU 5BH ;Unidades de Horas del Alarma
    DHA EQU 5CH ;Decenas de Horas del Alarma
    ;Para multiplexor se usa el valor 20h de la memoria
    ORG 0000H
    SJMP inicio
    ORG 0003H ;VECTOR DE INTERRUPCIÓN EXTERNA 0
    CPL ROA ;Cambio entre alarma y reloj
    CPL P0.0
    RETI
    ORG 000BH ;Vector de interrupción Temp0
    JMP INTT0
    ORG 0013H ;Vector de interrupción Ext1
    SETB INT1 ;Apaga la interrupción uno para evitar múltiples cambios de minutos
    JMP INTEX1
    ORG 0040H
    INICIO: MOV TMOD, #00100010 B ;Inicia los dos temporizadores en modo 2, disparados por software y como temporizadores
    MOV TH0, #-250 ;Recarga del temporizador de inicio (250us)
    ;Inicialización de registros y variables
    SETB ROA ;INICIA EN MODO RELOJ
    SETB TR0 ;ACTIVA EL TEMPORIZADOR 0
    SETB IT1 ;INT EXTERNA 1
    SETB IT0 ;INT EXTERNA 0
    CLR A
    MOV P1, #0FEH ;MANDA AL PUERTO 1 (MULTIPLEXOR) UN 11111110b
    SETB P2.7 ;MANDA 5V AL BUZZER
    ;Inicia el reloj en 12:00:00
    MOV R2, #5
    MOV R3, #5
    MOV R4, #6
    MOV R5, #5
    MOV R6, #23
    NOP
    MOV A, AIR
    CLR A
    MOV AIR, A
    MOV USR, #0
    MOV DSR, #0
    MOV UMR, #6
    MOV DMR, #5
    MOV UHR, #3
    MOV DHR, #2
    ;TABLA DECODIFIDORA
    ; gfedcba
    MOV 60H,#1000000B ;0
    MOV 61H,#1111001B ;1
    MOV 62H,#0100100B ;2
    MOV 63H,#0110000B ;3
    MOV 64H,#0011001B ;4
    MOV 65H,#0010010B ;5
    MOV 66H,#0000010B ;6
    MOV 67H,#1111000B ;7
    MOV 68H,#0000000B ;8
    MOV 69H,#0011000B ;9
    ;Inicia la alarma en 18:00:00
    MOV USA, #0
    MOV DSA, #0
    MOV UMA, #9
    MOV DMA, #5
    MOV UHA, #9
    MOV DHA, #1
    SETB P2.5
    MOV 20h, #0FEH
    MOV IP, #05H ;Da prioridad a las interrupciones externas
    MOV IE, #87H ;Habilita interrupciones (EA, EX1, ET0, EX0)
    JMP $
    ;Inicia el conteo
    INTT0: INC R1
    CJNE R1,#8,REGRESAR ;Mientras R1 != 8 regresa
    ACALL MULT ;Si no, Manda a llamar al multiplexor
    INC R2 ;Incrementa los segundos
    ACALL COMP
    MOV A, R1 ;MUEVE R1 AL ACUMULADOR *
    CLR A ;Pone A n ceros
    MOV R1, A ;Mueve A a R1
    CJNE R2,#23,REGRESAR
    INC R3
    MOV R2, #1
    CJNE R3,#20,REGRESAR ;CONTADOR DE 1 SEGUNDO
    MOV AIR, #0 ;Reinicializa la variable del contador
    ACALL DISP ;Subrutina para obtener el valor de cada display
    ACALL ALARMA ;Subrutina para activar la alarma
    MOV R3, #0
    INC R4
    CJNE R4,#60,REGRESAR ;CONTADOR DE 60 SEG O 1 MIN
    MOV R4, #0
    INC R5
    SETB P0.1 ;Después de un minuto apaga por completo la alarma
    ; ACALL INTEX1
    CJNE R5,#60,REGRESAR ;CONTADOR DE 60 MIN O 1 HORA
    MOV R5, #0
    INC R6
    CJNE R6,#25,REGRESAR
    MOV R6, #1
    REGRESAR: RETI
    ;Subrutina para el multiplexor
    MULT: MOV A, 20h
    RL A ;Mueve el bit en 0 a la derecha
    MOV 20h, A
    MOV P1, 20h ;Envia el valor de 20h al puerto 1
    JNB 00h, MUS ;Muestra Unidades de Segundos
    JNB 01h, MDS ;Muestra Decenas de Segundos
    JNB 02h, MUM ;Muestra Unidades de Minutos
    JNB 03h, MSM ;Muestra Decenas de Minutos
    JNB 04h, MUH ;Muestra Unidades de Horas
    JNB 05h, MDH ;Muestra Decenas de Horas
    EPRT: RET
    ;ROA = 0 -> alarma, ROA =1  -> reloj
    MUS: JNB ROA, MSUA ;Mostrar Segundos Unidades Alarma
    MOV A, USR
    JMP PRINT
    MSUA: MOV A, USA
    JMP PRINT
    MDS: JNB ROA, MSDA ;Mostrar Segundos Decenas Alarma
    MOV A, DSR
    JMP PRINT
    MSDA: MOV A, DSA
    JMP PRINT
    MUM: JNB ROA, MMUA ;Mostrar Minutos Unidades Alarma
    MOV A, UMR
    JMP PRINT
    MMUA: MOV A, UMA
    JMP PRINT
    MSM: JNB ROA, MMDA ;Mostrar Minutos Decenas Alarma
    MOV A, DMR
    JMP PRINT
    MMDA: MOV A, DMA
    JMP PRINT
    MUH: JNB ROA, MHUA ;Mostrar Horas Unidades Alarma
    MOV A, UHR
    JMP PRINT
    MHUA: MOV A, UHA
    JMP PRINT
    MDH: JNB ROA, MHDA ;Mostrar Horas Decenas Alarma
    MOV A, DHR
    JMP PRINT
    MHDA: MOV A, DHA
    JMP PRINT
    ;Suma al valor del acomulador (Un número del uno al nueve) 60H, dirección
    ;donde se encuentran los segmentos de cada número
    PRINT: ADD A, #60H ;Inicio de Tabla
    MOV R0, A ;Mueve ese valor a R0
    MOV P2, @R0 ;Mueve el contenido de R0 a P2
    JMP EPRT
    DISP: MOV A, R4 ;Mueve los segundos al acomulador
    MOV B, #10
    DIV AB ;Divide A entre B, como B es 10 convierte el numero de dos dígitos en
    ; un cociente de uno y un residuo de uno
    MOV USR, B ;B es la parte Unidades de los segundos (Residuo)
    MOV DSR, A ;A es la parte alta de los segundos (Cociente)
    MOV A, R5 ;Mueve los minutos al acomulador
    MOV B, #10
    DIV AB ;Divide A entre B, como B es 10 convierte el número de dos dígitos en
    MOV UMR, B ;B es la parte baja de los minutos (Residuo)
    MOV DMR, A ;A es la parte alta de los minutos (Cociente)
    MOV A, R6 ;Mueve las horas al acomulador
    MOV B, #10
    MOV UHR, B ;B es la parte baja de las horas (Residuo)
    MOV DHR, A ;A es la parte alta de las horas (Cociente)
    RET
    ALARMA: MOV A, UMA
    CJNE A, UMR, UMAR ;Sí minutos es igual en alarma y reloj incrementa AIR
    INC AIR
    UMAR: MOV A, DMA
    CJNE A, DMR, DMAR ;Sí minutos es igual en alarma y reloj incrementa AIR
    INC AIR
    DMAR: MOV A, UHA
    CJNE A, UHR, UHAR ;Si horas es igual en alarma y reloj incrementa AIR
    INC AIR
    UHAR: MOV A, DHA
    CJNE A, DHR, DHAR ;Si horas es igual en alarma y reloj incrementa AIR
    INC AIR
    DHAR: MOV A, AIR
    CJNE A, #4, REG ;Si todas las comparaciones fueron correctas, AIR debe valer 4
    CPL P0.1 ;Enciende el buzzer
    ;MOV A, DHR
    ;CJNE A, #2, REG
    ;MOV A, UHR
    ;CJNE A, #3, REG
    ;MOV A, DMR
    ;CJNE A, #5, REG
    ;MOV A, UMR
    ;CJNE A, #9, REG
    ;MOV A, DSR
    ;CJNE A, #5, REG
    ;MOV A, USR
    ;CJNE A, #9, CERO
    ;CALL INTEX1
    REG: RET
    INTEX1: JNB ROA, INTEX1A ;Si ROA es cero, cambia a una subrutina para aumentar la alarma
    MOV A, R5
    CJNE A, #59, INC0 ;Si los minutos NO son 59, llama a una subrutina para aumentarlos en 1
    MOV R5, #0 ;Si son 59, los cambia a 0, e intenta aumentar horas
    MOV A, R6
    CJNE A, #23, INC1 ;Si las horas NO son 23, llama a una subrutina para aumentarlos en 1
      ;CJNE A, #24, INC1
    MOV R6, #0 ;Si son 23 los vuelve 0
    JMP REGR
    INC0: ADD A, #1 ;Aumenta una minuto
    ;ADD A, #1
    MOV R5, A
    JMP REGR
    INC1: MOV A, R6
    ADD A, #1 ;Aumenta una hora
    MOV R6, A
    JMP REGR
    INTEX1A: MOV A, UMA
    CJNE A, #9, INC4 ;se sigue con el siguiente valor
    MOV UMA, #0
    MOV A, DMA
    CJNE A, #5, INC5
    MOV DMA, #0
    NOP
    MOV A, UHA
    CJNE A, #9, INC6
    MOV UHA, #0
    MOV A, DHA
    CJNE A, #2, INC7
    MOV A, UHA
    INC4: ADD A, #1 ;Incrementa UNIDADESvde los minutos
    MOV UMA, A
    JMP REGR
    INC5: ADD A, #1 ;Incrementa DECENAS de los minutos
    MOV DMA, A
    JMP REGR
    INC6: MOV A, DHA
    CJNE A, #2, INC8 ;Cambio para las 24 hrs
    MOV A, UHA
    CJNE A, #3, INC8
    MOV DHA, #0
    MOV UHA, #0
    JMP REGR
    INC7: MOV A, DHA ;Incrementa las unidades de horas
    ADD A, #1
    MOV DHA, A
    JMP REGR
    INC8: MOV A, UHA ;Incrementa las decenas de horas
    ADD A, #1
    MOV UHA, A
    REGR: RETI
    CERO:
    MOV DHR,#2
    MOV UHR,#3
    MOV DMR,#5
    MOV UMR,#9
    MOV DSR,#5
    MOV USR,#9
    MOV R6, #0
    RETI
    COMP: CJNE R6,#24,NADA
    JMP CERO
    RETI
    NADA: RETI
    END
View all instructions
