You can add new function to every key, and make the led response according to the function. The led it's connected to pwn.
Check the github link to see the source code.
A mechanical keyboard for shortcuts with Arduino Pro Micro. It automate the generation of new password and puts on clipboard
I redesigned the pcb, with a different design for the keys; add a rotary encoder to take better advantage of the arduino space.
One of the advantage of this design, is the a can do a better panelize de boards.
Make a custom cabinet to print in 3d for the keyboard.
