Today i split my time between Rupert and my wearable head.
First I added Rupert's head to the stick and glued the controller to the bottom.
next I glued up some foam to make a body:
Next i cut a hole in his side for my hand to access the wiimote:
Finally a sewed up a body covering with darts at the top to sit underneath the head fur.
Next up, arms and legs!
Kevin Harrington
