Hardware:
The hardware for this project was, for the most part, successful. We were able to achieve our major goals of creating a lightweight and durable case that houses a compartmentalized electronics system, along with a system of mirrors and a lens to display an OLED image onto the retina. The whole case is also easily portable, lightweight, and wearable, as we were able to attach it to a pair of large safety goggles. Below are several pictures of the goggles on a person.
Side view of the Data Glasses, with a fully parallel and appropriately angled Data Glasses case attached to the side of the goggles
Top View of the Data Glasses, showing the angle of the reflector towards the eye.
A side-by-side comparison of our Data Glasses with the Google Glass, a similar wearable HUD created by Google
Software:
The software aspect of our project was far less successful. We had serious difficulties in connecting the Bluetooth module to the computer and running a connection between the Data Glasses and the SoftwareSerial on the computer. There was some unidentified issue in the connection and pairing process, as the computer was unable to connect to the HMSoft Bluetooth output of the module. Thus, the Bluetooth aspect of the Data Glasses was a failure. However, the OLED worked perfectly and we were easily able to code it to display text and images. The final product incorporates a stopwatch timer displayed on the OLED screen that can be started and stopped through the press of a pushbutton on the exterior of the glasses.
