Install
- Add json link to Arduino - Preferences
http://wizio.eu/arduino/bc66/package_wizio.bc66_index.json
- Open Borad Manager, Find WizIO, Install OR Update, Select board, Click [Compile] or [Upload]
Arduino + OpenCPU + ExtendedAPI gives you tremendous opportunities for LTE Narrow Band
The extended API is dependent on firmware version.
The exAPI support direct calls to the core as FreeRTOS, lvip, mbedtls, http, mqtt...etc.
exAPI is selected as board model in Arduino Menu - Boards Manager.
Firmware, USB Drivers, Quectel IoT Flash Tool https://app.box.com/s/3wrkh1yzn09yuyb5f8v5vllmlir0571s
Georgi Angelov
deqing
Javier Fernández
Simon
upload to the module (as ESP32)... port is based of Quectel OpenCPU
