I would recreate the entire layout, however I don't know that there is a better way to generate the 0.1" prototyping grid, and I'll probably eliminate most of the drill holes to make it easier to mill.
A project log for 2018 SuperCon Ⅹ-proto (RE: proto-board)
Reverse Engineering of 2018 Hackaday Superconference Badge "proto-board"
