Added scaled reference image, rotation and scale is corrected, there is still some skew, particularly from top to bottom along the sides. The image resolution is adjusted to 640 pixels per inch in GIMP, this results in the 0.1" hole spacing equating to 64 pixels. Also added some transparent PNG's that were pulled and scaled from data sheets as basic references for assessing footprints.
