Laser cut 1:1 size board references. These two cuts were generated from new outlines based on the actual badge. The files are available as .dxf and .svg. These were done to sanity check the process of creating new expansion boards that would be compatible. Also with these I can actually hold the "board" in my hand and get a feel for the form factor and usability.
