over the next few nights i will start putting this all together in prototype form.
I have modep image on a card, and just need to iron out some config issues to be up and running.
For the footswitch testing I gave attached a little dual analog stick board to simulate the footswitch. The board has potentiometers to simulate an expression pedal input, and clickable buttons in the centre of the sticks to test out the footswitches in my code.
I've also dug out an old Stagg case I used to carry a few pedals in, and this will form the base of my board.
Once the Pi, interface and footswitch are in all that's left to do is build two expression pedals to operate pots for the Pi and enclose all the wiring for a neat finish.
