• Trying to optimize the transformers
    wesley lee • 11/02/2018 at 19:17 • 0 comments
    So, I was trying to optimize the amount of transformer windings:
    For the battery to be usable at lower voltages, the cores need more turns. However it is more work, so there must be a point of diminishing returns as battery life isn't a super important goal in this project.
    I was winding one or two transformers with 20, 25, 30 turns, and testing them. If they looked promissing, I would wind one or two more to complete a byte.
    However, when winding the 3rd 30 turn transformer, something threw me off. The third one had quite a different waveform. I thought maybe I took a toroid from another batch?
    Took me 18 hours to find out, but the glue I was using to glue the toroid on the 3D print changes the characteristics of the transformers.. Facepalm. I had to let the glue cure before measuring them.
    Blue waveform of recently glued toroid:
    18 hours later..:
  • Coil and Latch waveforms
    wesley lee • 10/26/2018 at 22:55 • 0 comments
    Just took a screenshot of the scope to show how the coils trigger the SR Latch:
    Yellow is the pulse out of the 3-8 decoder, Light blue the pulse out of the toroid, Purple the output of the SR Latch, and Dark Blue the "Reset" signal from the Atmega328/Arduino to clear the Latch.
