Hackaday.io Hackaday.io
Sign up Log in
Linear Servo Actuators
This is a general purpose 3D printed linear servo actuator (pusher style). Hope these save you some time on a future project!
aliAli
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
18 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
899
0
18
19
Team (1)
  • aliAli
Join this project's team
  • Assembly video
completed project
Linear servo actuator diy 3D printed 3d printing
This project was created on 10/28/2018 and last updated 8 years ago.
Description
This is a general purpose linear servo actuator (pusher style). Two sizes have been designed, for different space constraints and force outputs.
These use continuous rotation servos which helps keep the cost very low. Off the shelf actuators of this type can cost around $70 USD.
The “mini” version will fit in smaller spacers, but has a much lower force output. The “large” version has a higher force output, but is...larger in size than the “mini”.
Here is a video that shows how to assemble and run both sizes:
https://youtu.be/2vAoOYF3m8U
Links to STL files and a full parts list can be found in the video description.
**Please note that the best way to show your appreciation and keep up to date on my latest 3D printing projects is to head over to my YouTube channel and subscribe!**
Project Logs
Collapse
  • Assembly Video and Link to STL files
    Ali • 10/28/2018 at 13:10 • 2 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
Combine two DJI FPV goggles into a single pair of stereoscopic FPV goggles.
Project Owner Contributor
3D FPV Goggles
nathan-petersonNathan Peterson
Simple approach to a modular revolute actuator
Servo with integrated slew bearing
wmacalusowmacaluso
2021 Hackaday Prize
A new breed of robotic hand
LUXE Gen-6
ian-madayIan Maday
Robust yet simple and relatively cheap linear actuator for hobbyists !
Robust linear actuator
mogensmogens
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Linear Servo Actuators", please tell us the reason.
Send message
Remove Member
