1Step 1
Acquire all necessary parts. (Completed)
2Step 2
Populate and test at least two boards. This is going to be a lengthy process.
3Step 3
With the last step done, make note of any changes and breath a sigh of relief that the board works as expected. Now move on to the next sub project in the hamster ball saga.
4Step 4
Wire up the Teensy 3.1 and the camera.
5Step 5
Play with the SCCB interface and get the image set up as desired.
6Step 6
Transfer system to wireless communications using nRF24L01+, all the while using a power supply. This means setting up the Pi to recieve the transmissions
7Step 7
Transfer system over to wireless power, and do brownout tests.
8Step 8
With all of this on a breadboard, we now need to cad up the schematic, and home print a test board.
9Step 9
Populate and test the homemade board. Fix any necessary problems. When complete, we are 100% sure this is what we want as a final product.
10Step 10
Prepare the files for the fab house, including the solder mask and gerber files.
