Arduino-Code:
#include <SoftwareSerial.h>
#include <Crc16.h>
#include <EEPROM.h>
#include <WTV020SD16P.h>
Crc16 crc;
SoftwareSerial BTSerial(8, 7);
uint8_t configs[18] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
uint8_t configsbuf[18] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
int ledpin = 3;
int bwmPin = 2;
int resetPin = 10; // The pin number of the reset pin.
int clockPin = 6; // The pin number of the clock pin.
int dataPin = 12; // The pin number of the data pin.
int busyPin = 11; // The pin number of the busy pin.
WTV020SD16P WTV020SD16P(clockPin, dataPin, busyPin, resetPin);
unsigned short crcrx = 0;
boolean shot = true;
String inputString = ""; //Serial Buffer
boolean stringComplete = false; //Serial Helper
boolean block = false;
boolean receiveconfig = 0;
int minlight = 0;
int maxlight = 0;
String worker = "";
unsigned long previousMillis = millis();
unsigned long previousbwmMillis = millis();
unsigned long previoussoundMillis = millis();
int lastbwmstate = LOW;
unsigned long lastlow = millis();
boolean lowtime = LOW;
int fract = 0;
int fractdelay = 0;
int itlast = 0;
int itcnt = 0;
//sound
int soundstart = 0;
//delay
int it = 0;
unsigned int fordelay = 0;
int delayer = 0;
int steps = 0;
unsigned long currentMillis = millis();
int randermin = 0;
int randermax = 0;
int busyPinstate = LOW;
unsigned long lastserial = millis();
int bwmstate = LOW;
void setup() {
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
Serial.begin(57600);
BTSerial.begin(9600); //BTserial
inputString.reserve(100);
pinMode(ledpin, OUTPUT);
pinMode(bwmPin, INPUT);
pinMode(busyPin, INPUT);
analogWrite(ledpin, 255);
load_config();
delay(1000);
WTV020SD16P.reset();
delay(1000);
bwmstate = digitalRead(bwmPin);
if (bwmstate == HIGH)
Serial.println("HIGH");
minlight = configs[0];
maxlight = configs[1];
fract = configs[2] ;/// 4;
fractdelay = configs[3];
} else {
minlight = configs[4];
maxlight = configs[5];
fract = configs[6];// / 4;
fractdelay = configs[7];
boolean firststart = true;
void loop() {
MyserialEvent();
serialmenu();
busyPinstate = digitalRead(busyPin);
lastlow = currentMillis;
unsigned long temp = configs[14] * 1000;
if ( currentMillis - lastlow >= temp)
lowtime = HIGH;
} else {}
if (configs[12] == 1) {
blinking();
} else analogWrite(ledpin, 0 );
if (configs[13] != 0 && configs[12] != 0 )
soundcheck();
if (bwmstate != lastbwmstate) {
lastbwmstate = bwmstate;
Serial.println("toggle");
int bwmsteps = 0;
boolean clearinput = false;
unsigned long lastcall = 0; int i = 0;
int lastbwm = LOW;
boolean startsound = true;
unsigned long lastsound = millis();
unsigned long delaysound = millis();
unsigned long lastloww = millis();
boolean lowwtime = LOW;
boolean ledstate = LOW;
int lastledstate = LOW;
void soundcheck() {
if ( currentMillis - lastsound >= (configs[10] * 2000) && configs[8] != 0 && lowtime)
if ( bwmstate == HIGH && lastbwmstate == LOW ) {
lastbwmstate = HIGH;
startsound = true;
delaysound = currentMillis;
Serial.println("SOUNDTIME");
if ( startsound && currentMillis - delaysound >= configs[11] * 2000 && startsound )
Serial.println("Sound");
delay(200);
WTV020SD16P.setVolume(configs[8]);
delay(300);
WTV020SD16P.asyncPlayVoice(configs[9]);
startsound = false;
lastsound = currentMillis;
lowtime = LOW;
void MyserialEvent() {
if (millis() - lastserial > 1000)
inputString = "";
while (BTSerial.available()) {
char inChar = (char)BTSerial.read();
inputString += inChar;
if (inChar == '\n') {
stringComplete = true;
worker = inputString;
inputString = "";
void serialmenu() {
if (stringComplete)
Serial.println(worker);
if (worker == "XXCHECKXX\r\n")
String temp = "";
block...
Kirschner Christoph
Hi! I working on a robotics project... Check it out! Do drop a like too :P
https://hackaday.io/project/165046-autonomous-navigation
