The updated front panel finished up and I took it with me to the first day of Supercon around 5pm, where I got to assemble it.
It works! Everything fits!
The only thing I didn't get to try was the door for the expansion board; the board fits fine as you can see. I made a couple of changes to give it a little extra clearance and reuploaded the file.
So all of the files are good to use now! Go get them and print them, if you still have time!
