The BF592A initialization is working fine. The PLL is set and the mais clock is 193.577MHz.
Unfortunately, the pin VDDD is currently tied to +3V3 but the datasheet says it have to be connected to 1.1 ~ 2.0V... let's see if the little cut can save it.
