Set up Raspberry Pi 3 or Zero W networking using systemd.
Including simultaneous AP + STA.
Download the image from: https://www.raspberrypi.org/downloads/.
Use whichever method you are more comfortable with - NOOBS or RASPBIAN - to install and load the image onto a MicroSD card.
In my case I am using Raspbian Stretch Lite. Downloaded and unzipped the image, and then used the Disks utility in Ubuntu Linux to restore the image onto the SD card.
This step is only applicable to Raspberry Pi Zero W, as Pi 3 does not have a USB OTG port.
Additionally, if you have a monitor and keyboard connected to your Pi Zero W, you can also skip this step.
Otherwise, with your SD card plugged into the PC, modify/create the following files:
a) Go to the boot partition, open the config.txt file and add the following at the very end:
dtoverlay=dwc2
b) Next, open the cmdline.txt file and add the following at the end of the line:
modules-load=dwc2,g_ether
c) Create an empty file called ssh.
If you have a monitor and keyboard connected, simply log into the Pi with username pi and password raspberry.
Otherwise, if using Ethernet over USB emulation (Pi Zero W only), do the following:
a) Make sure Avahi/Bonjour service is running. If you are on Mac or Linux, it most likely is. On Windows, download and install iTunes - it comes bundled with Bonjour.
b) Connect the Pi to your PC via USB cable. Use the USB port labelled "USB" on the Pi (not the "PWR IN" one).
c) Open a terminal application in your PC and log into the Pi using ssh (use PuTTY or similar on Windows):
ssh pi@raspberrypi.local
Password is the same as above.
