I found some time to fix some little bugs.
With this release you can:
- press ALT + VIB ON to trigger a whole "analog sync": all the drawbars are read and the corresponding CC or SysEX Value is sent via MIDI, so you can be sure that the sound engine is "synced" to the Commander.
- press ALT + FAST to send a "All sound off" (CC 120)... just "in case" ;-)
You can download from: https://github.com/garubi/MIDI-Drawbars-Commander/releases/tag/v1.3.3
