I’ve been really busy with another projects like CALE Eink calendar but I still think that this one can be a good example for anyone dealing with SPI interfaces and is fun to build so I though about making an upgrade so it is:
- Easier to install using PlatformIO
- Only one codebase for both ESP8266 and ESP32 (now that I have a bit more experience using #ifdef)
- Add zlib compression to send the image in ESP32 version (will reduce at least 3 times upload time)
- More customizable. Moving all config / SPI and so on into Config and leaving most configuration in a single place
So that’s it. I wish you all a great start of 2020, build cool stuff and learn a lot in the process
Martin Fasani
