Just pulled the trigger on a v1.1 board order. Notable changes:
- Thicker solder through holes for the Teensy
- Proto-holes underneath the Teensy breakout. Each pad is connected to at least one extra hole. VIN, GND and 3.3V are each connected to two extra pads.
