The USB hub arrives and claims to be USB 3.0 P/N 30420
It has a micro USB port for an external power supply.
I tested it with my PC it and works fine.
A little gentle application of a spudger and the case has yielded the board.
The plan is to remove the mic and headphone sockets and wire the circuitry i've created to adapt pc level to NATO headset compatible levels in between this board and my Type 626 socket. That way to use the headphones they just have to be plugged into this box.
The Audio chip appears to be HS-100B
The USB chip appears to be GL3520
