In the comments @matseng said that he wants to build a memory system that also heats his room with 3000 Watt. Problem is, that the first design generates 1.1 Watt for 2 bits storage. So he can only store 5454 bits (680 bytes).
I made a new version for him, that uses only 50mW for two bits (10 mA at 5 volts). Now his 3000 Watt heating system will have 120kbit storage (15 kilobyte). That will be enough for some very nice programs !
The supply voltage was dropped from 12 volt to 5 volt, and low-current LEDs are used. All resistors were re-calculated. The file section has the Falstad model for this design.
(Note that in the Falstad simulator, you can edit the properties of a LED, and set the current that is needed to let them fully light up. So I did set that to 1 mA for this simulation.)
